Hello Dr. Kohlmeyer. I see that dihedral_style multi/harmonic command allows the summation of harmonic terms. I was curious if there is the same options for bond_style and angle_style where I can obtain a bond and angle potential consisting of a sum of multiple harmonic terms.
The manual does not specify multi/harmonic options for bond_style and angle_style. I used the hybrid command but, unfortunately, it seems that I cannot use the same bond style twice. I would greatly appreciate if I could request for any advice or suggestions.
LAMMPS will not complain if you define multiple bonds (and multiple
3-body angle and 4-body dihedral) interactions between the same atoms,
and you can use different parameters each time. (This is the reason I
replied to the thread.) However that's not a good idea. What Steve
suggested is much more efficient.
