Dear LAMMPS developers,
I would like to carry out MD simulation for the exfoliation of MoS2 in CH3OH solvent. I have prepared separately CH3OH and MOS2 data file from equilibration steps through MD ran separately by LAMMPS.
I created a free volume to accommodate MOS2 within CH3OH by using delete_atom command.
Next, I have two data files (MoS2 as atom id 1 and 2) CH3OH (atom id 1 2 3). I need to read two data files in a single input script using read_data command. I am facing problem to reset atom id as Mo S S C H O = 1 2 3 4 5 6.
Please suggest me appropriate commend to reset atom ids.
sample script is as given below
units real
atom_style full
read_data LAMMPS_MoS2_2.data
read_data data.METHANOL add append IDoffset 3
pair_style reax/c lmp_control checkqeq no
pair_coeff * * ffield_MoS2 Mo S S C O H
you need to reserve space for additional atom types when reading the first data file. one the simulation box is created (which is implicit in read_data), the number of atom types and various other settings are locked in and cannot be changed. thus the need to reserve space for additional types and storage for per-atom properties (atoms, bonds, angles, dihedrals, special atoms etc.)
for details please re-read the (extensive) read_data documentation and particularly the paragraph starting with:
The {extra} keywords can only be used the first time the read_data
command is used. They are useful if you intend to add new atom, bond,
angle, etc types later with additional read_data commands. This is
because the maximum number of allowed atom, bond, angle, etc types is
set by LAMMPS when the system is first initialized
