Dear Lammps users and Aidan (Aidan Thompson)
I am trying to calculate the atomic charges of a molecule by using fix qeq/reax with Dreiding ff. When the simulation starts the energy term turns to be nan (not a number) at the first step, it may be due to some errors in charge calculations. I attached the in and data files.
Please advise me.
baris
chargein2.lammps (594 Bytes)
nDETDAev.data (5.16 KB)
or a bad initial structure, bad parameters, bad units, and other things.
but not param.qeq
Metal units is inconsistent with fix qeq/reax.
Lj/cut/coul/cut with 5.0 cutoff is bad.
You structure may be bad.
No ones knows what is in the param.qeq.
Ray
Hi Ray,
I checked my structure and did a short run and visualised it in VMD, hence no problem in my data file.
I used metal units because the terms in param.qeq must be in eV as indicated in the manual. You mean I should use real units where kcal/mol is energy unit, but the terms in the param.qeq file must be in eV. Am I right?
Do I need to assign any initial charges to atoms?
I attached the param.qeq file.
Baris.
Ray
param.qeq (136 Bytes)
Where did you get those QEq parameters? They look suspicious. Moreover, you have 4 atom types and only three entries in param.qeq - I don’t know how that could have worked.
Bad QEq parameters would no doubt lead to bad results.
Ray
Hi Ray,
To simplify the problem I tried the fix qeq/reax for one water molecule. I attached the data, in, and param files. I took the data for param file from the QEq original paper: J. Phys. Chem. 1991, 95, 3358.
Two problems arise:
- When you run without ewald, the charges are nan,
- When you run with ewald, a segmentation fault occurs.
And a question: do I have to assign initial charges to atoms?
You can check the files.
baris
Ray
param.qeq (95 Bytes)
water.data (677 Bytes)
waterin.lammps (835 Bytes)
For some reason your system/setup does work with the JPC parameters, but it does work with the QEq parameters from the examples/reax/CHO/param.qeq file.
This is not a bug but related to the sensitivity of the current QEq implementation to its parameters.
Ray
