I am trying to compute the forces on carbon atoms in a certain
configuration (the configuration corresponds to a symmetric tilt grain
boundary, however, this should have no significance). I have checked
out the exact same version of LAMMPS from the svn repository on two
different machines. On one machine I get reasonable answers, while on
the other I get nan. I have tried checking out the latest version of
LAMMPS and the problem persists. The machine on which things work
yields
$ uname -a
Linux mc1 3.0.0-13-generic #22-Ubuntu SMP Wed Nov 2 13:25:36 UTC 2011
i686 i686 i386 GNU/Linux
while the machine where things don't work yields:
$ uname -a
Linux mc2 2.6.18-274.7.1.el5 #1 SMP Thu Oct 20 15:20:36 EDT 2011
x86_64 x86_64 x86_64 GNU/Linux
I run LAMMPS by invoking the following:
lmp_serial < input
NOTE: The relevant files are temporarily available at:
http://dhruv.ccmr.cornell.edu/ashivni/
The input script is also appended (below are the contents of file called input):
clear
variable dump_file string "./trj"
variable data_file string "./data"
boundary s p p
atom_modify sort 0 0.0
neighbor 2.0 bin
read_data ./data
### interactions
pair_style airebo 2.0
pair_coeff * * CH.airebo C
mass * 12.0
### run
fix fix_nve all nve
dump dump_all all custom 1 ./trj id type x y z vx vy vz fx fy fz
thermo_style custom step temp press cpu pxx pyy pzz pxy pxz pyz ke pe
etotal vol lx ly lz atoms
thermo_modify flush yes
thermo 1
run 0
log /dev/stdout
The contents of the file named data are appended below:
./data
51 atoms
1 atom types
0.0 11.174734400 xlo xhi
0.0 16.935806774 ylo yhi
0.0 10.000000000 zlo zhi
Atoms
1 1 3.467160896 0.259221532 5.000000000
2 1 2.569191168 2.505808145 5.000000000
3 1 3.666709725 1.641736371 5.000000000
4 1 2.768739996 3.888322984 5.000000000
5 1 4.065807382 4.406766048 5.000000000
6 1 4.265356211 5.789280887 5.000000000
7 1 1.671221439 4.752394758 5.000000000
8 1 1.870770268 6.134909597 5.000000000
9 1 3.167837654 6.653352661 5.000000000
10 1 2.269867925 8.899939274 5.000000000
11 1 3.367386482 8.035867500 5.000000000
12 1 2.469416754 10.282454113 5.000000000
13 1 4.664453868 8.554310564 5.000000000
14 1 3.766484139 10.800897177 5.000000000
15 1 4.864002696 9.936825403 5.000000000
16 1 3.966032968 12.183412016 5.000000000
17 1 1.571447025 12.529040726 5.000000000
18 1 2.868514411 13.047483790 5.000000000
19 1 1.970544682 15.294070403 5.000000000
20 1 3.068063239 14.429998629 5.000000000
21 1 2.170093511 16.676585242 5.000000000
22 1 4.365130625 14.948441694 5.000000000
23 1 4.564679454 16.330956532 5.000000000
24 1 7.707573504 0.259221532 5.000000000
25 1 8.605543232 2.505808145 5.000000000
26 1 7.508024675 1.641736371 5.000000000
27 1 8.405994404 3.888322984 5.000000000
28 1 5.587367200 2.160179435 5.000000000
29 1 7.108927018 4.406766048 5.000000000
30 1 5.587367200 3.542694274 5.000000000
31 1 6.909378189 5.789280887 5.000000000
32 1 5.587367200 6.307723952 5.000000000
33 1 9.503512961 4.752394758 5.000000000
34 1 9.303964132 6.134909597 5.000000000
35 1 8.006896746 6.653352661 5.000000000
36 1 8.904866475 8.899939274 5.000000000
37 1 7.807347918 8.035867500 5.000000000
38 1 8.705317646 10.282454113 5.000000000
39 1 6.510280532 8.554310564 5.000000000
40 1 7.408250261 10.800897177 5.000000000
41 1 6.310731704 9.936825403 5.000000000
42 1 7.208701432 12.183412016 5.000000000
43 1 5.587367200 12.701855081 5.000000000
44 1 5.587367200 14.084369919 5.000000000
45 1 9.603287375 12.529040726 5.000000000
46 1 8.306219989 13.047483790 5.000000000
47 1 9.204189718 15.294070403 5.000000000
48 1 8.106671161 14.429998629 5.000000000
49 1 9.004640889 16.676585242 5.000000000
50 1 6.809603775 14.948441694 5.000000000
51 1 6.610054946 16.330956532 5.000000000
lmp_serial -h tells me the following on both machines:
LAMMPS (19 Dec 2011)
List of style options included in this executable:
Atom styles: atomic charge ellipsoid hybrid line sphere tri
Integrate styles: respa verlet
Minimize styles: cg fire hftn quickmin sd
Pair styles: adp airebo born/coul/wolf born buck/coul/cut buck comb
coul/cut coul/debye coul/wolf dpd dpd/tstat eam/alloy eam/fs eam eim
gauss hybrid hybrid/overlay lj96/cut lj/class2/coul/cut
lj/class2/coul/long lj/class2 lj/cubic lj/cut/coul/cut
lj/cut/coul/debye lj/cut lj/expand lj/gromacs/coul/gromacs lj/gromacs
lj/smooth morse rebo soft sw table tersoff tersoff/zbl yukawa
Bond styles: class2 hybrid
Angle styles: class2
Dihedral styles: class2
Improper styles: class2
KSpace styles:
Fix styles (upper case are only for internal use): adapt addforce
ave/atom ave/correlate aveforce ave/histo ave/spatial ave/time
box/relax deform deposit drag dt/reset efield enforce2d evaporate
external gravity heat indent langevin lineforce MINIMIZE momentum move
nph nph/sphere npt npt/sphere nve nve/limit nve/noforce nve/sphere nvt
nvt/sllod nvt/sphere orient/fcc planeforce press/berendsen print
qeq/comb READ_RESTART recenter RESPA restrain rigid rigid/nve
rigid/nvt setforce shake SHEAR_HISTORY spring spring/rg spring/self
store/force store/state temp/berendsen temp/rescale
thermal/conductivity tmd ttm viscosity viscous wall/harmonic
wall/lj126 wall/lj93 wall/reflect wall/region
Compute styles: angle/local atom/molecule bond/local centro/atom
cluster/atom cna/atom com com/molecule coord/atom dihedral/local
displace/atom erotate/sphere group/group gyration gyration/molecule
heat/flux improper/local ke/atom ke msd msd/molecule pair pair/local
pe/atom pe pressure property/atom property/local property/molecule rdf
reduce reduce/region slice stress/atom temp/com temp/deform temp
temp/partial temp/profile temp/ramp temp/region temp/sphere ti
Region styles: block cone cylinder intersect plane prism sphere union
Dump styles: atom cfg custom dcd image local xyz
Command styles (add-on input script commands): change_box create_atoms
create_box delete_atoms delete_bonds displace_atoms displace_box
minimize read_data read_restart replicate run set velocity
write_restart
Any help will be appreciated!!
