Dear All,
I am trying to simulating the nanoindentation of a graphene sheet. The entire simulation is occuring properly. The only problem I am facing is that, during the unloading process even when I reached the initial position of zero from where I have started indentation, the stress is showing a large negative value instead of zero, as some atoms remain stucked with the indenter up to that position.
Please can anybody address the probable reason of this problem?
Dear All,
LAMMPS is modeling what you tell it to do. the LAMMPS software is
extremely dumb (and deliberately so), it will execute the input exactly as
it is, regardless of whether that makes sense or not. so if that does not
behave the way you expect, is not a LAMMPS issue, but a user issue. in
other words, this either means, your expectations are wrong, or your input
is not describing the model correctly. nobody but you is in the position to
address this.
