ncoultablebits and tabinnersq ??
Dear Axel,
Would you please help me to understand two parameters called
in the pair_lj_cut_coul_long.cpp file
Many thanks
Arshia
Dear Axel,
the refer to tabulation of the coulomb potential.
if you cannot figure it out by yourself, you probably
better just set ncoultablebits to zero and ignore that
entire part of the code. tabulation is not a required
feature and can be done at a later points, if needed.
but to answer your question for real, ncoultablebits
is the number of bits used in tabulation. tabinnersq
is the rsq at which the force (and energy) begins.
for more info see the documentation to the pair_modify
options table table and tabinner.
http://lammps.sandia.gov/doc/pair_modify.html
