Hi Lammps-users,
I am trying to run the neb example, but i become this ERROR message:
mpirun -np 2 lmp_mpi -partition 2x1 -in in.diffusion
Hi Lammps-users,
I don’t know. Your command works fine
on the bench/in.lj input script.
Hi Lammps-users,
ERROR: Processor partitions do not match number of allocated processors
(../lammps.cpp:260)
(../lammps.cpp:260)
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status,
thus causing
the job to be terminated. The first process to do so was:Process name: [[51984,1],0]
Exit code: 1
##what am i doing wrong?
the fact you you get two error messages is worrisome. there should be only
one. do you get four, if you use mpirun -np 4?
if yes, it means, that either your lmp_mpi executable is not compiled for
use with MPI, or that your mpirun command belongs to a different MPI
library than what lmp_mpi was compiled with (e.g. MPICH vs. OpenMPI vs.
IntelMPI vs. MVAPICH).
if I do:
$ mpirun -np 4 lmp_mpi -partition 4x1 -in in.neb.hop1
ERROR: Processor partitions do not match number of allocated processors (…/lammps.cpp:260)
if I do:
(../lammps.cpp:260)
(../lammps.cpp:260)
this doesn't make sense. it would be either one line or four lines.
thus causing
the job to be terminated. The first process to do so was:Process name: [[51470,1],0]
Exit code: 1
--------------------------------------------------------------------------my mpi version is
$ mpirun --version
mpirun (Open MPI) 1.10.2Report bugs to
http://www.open-mpi.org/community/help/
I thought, if I used OpenMPI, i didnt need to specify the MPI variables.
what MPI variables and where are you talking about.
What do you recommend me ?
i can only repeat what i had said before. either you have inconsistent mpi
libraries or your executable was compiled for MPI stubs.
i cannot read minds of people nor those of computers, so i cannot know what
you have done exactly and what is going wrong on your computer.
all i can say from my (remote) position, that the command line works for
me, and that what you are seeing is not a LAMMPS error, but due to some
form of inconsistent usage.
thanks!
I did make ubuntu, and now the neb examples are working.
