Neb method
Dear all;
I run the example neb script listed in the examples folder using “mpirun -np 4 lmp_serial -partition 4x1 -in in.neb.hop1” but the simulation is failing with the following errors "ERROR: Processor partitions do not match number of allocated processors (…/lammps.cpp:260)
It looks like you are running lmp_serial in a parallel run.
You need a parallel LAMMPS, e.g. lmp_mpi.
