Dear Axel,
Many thanks for your comments.
About options to adjust the behavior in NEB: So far I tried adding a perpendicular spring force and changing minimization method, which helped me getting more reasonable answers. I believe that the perfect crystal (first replica) and twined structure (last replica) don’t need additional forces so i didn’t use end.
Unfortunately, latest version of patches didn’t help. I still have problem with centro-symmetry parameter in some replicas.
The following is my input script. I’d appreciate if I can have your comments.
Regards,
Leila
---------- Initialize Simulation ---------------------
clear
boundary p p f
atom_style atomic
atom_modify map array sort 0 0.0
variable u uloop 30
#----------- Create Box ----------------
region box prism 0.000000000000 39.620960716835 -0.000000000000 37.633348035685 -111.723599073640 111.723599073640 1.278095506995 0.000000000000 -0.000000000000 units box
create_box 1 box
read_dump s3Twin_0.dump 0 x y z box yes add yes
---------- Define Interatomic Potential ---------------------
pair_style eam/alloy
pair_coeff * * Cu01.eam.alloy Cu
neighbor 2.0 bin
neigh_modify delay 1 check yes
---------- Define Settings ---------------------
compute eng all pe/atom
compute eatoms all reduce sum c_eng
compute csym all centro/atom fcc
#saving atomic coordinates
dump 1 all custom 100 si_xyz_bulk.out id type x y z
thermo 10
thermo_style custom step pe lx ly lz press pxx pyy pzz c_eatoms
min_style cg
minimize 1e-25 1e-25 1000 10000
reset_timestep 0
timestep 0.03
Group of NEB atoms
region twinembryo prism 0.000000000000 39.620960716835 -0.000000000000 37.633348035685 -5 111.723599073640 1.278095506995 0.000000000000 -0.000000000000 units box
group nebatoms region twinembryo
group nonneb subtract all nebatoms
fix 1 nonneb setforce 0.0 0.0 0.0
fix 2 nebatoms neb 10 perp 1
#fix 3 all enforce2d
thermo 100
dump 2 all custom 100 dump.allatoms.$u id type x y z c_eng c_csym
run NEB for 100000 steps or to force tolerance
min_style fire
neb 1e-6 1e-6 100000 100000 100 final MyFile.txt.7
