Dear LAMMPS/ATC users:
I guess my questions should be addressed to Drs. Zimmerman, Jones, Templeton or other AtC folks.
I’m playing with AtC package trying to find the pros and cons of using a coupled FE/MD simulation for predicting the mechanical and thermal properties of solids. Most of the tests and input scripts provided with the package work fine and I am truly impressed with the ATC code, but sometimes I face with lack of some useful functionalities. Here are two examples:
After a few days of playing around with the simple input files found in the examples/USER/atc/thermal sub-directory of the LAMMPS public release (10 Aug 2015), I was confident that I could produce any script with minimal effort. Unfortunately I cannot visualize my results when I use the thermal fix and the binary output (Ensight *.case file): the temperature field is present in the text .DATA file, however, it is not displayed by Paraview. How can I sort out this problem? In particular, how can I generate with Paraview/EnSight software the temperature fields like those shown in Fig.7 in the paper of Wagner et al. (Comput. Methods Appl. Mech. Engrg. 2008, 197, 3351)?
My second question is related to the in.eshelby_static input file from the examples/USER/atc/hardy sub-directory. I understand that the FE region can be larger than the MD region, but how can I visualize the coarse-grained stress fields outside the MD domain, not only inside it? Rephrasing my question, is it possible to analyze the whole FE+MD domain when FE >> MD? In this regard I’d like to refer to a nice picture from Zimmerman’s presentation (2013) where J-integral calculations are discussed (see e.g. slide #9). I would be grateful for examples of the corresponding input scripts.
Thanks and best regards,
Helmut Grauer
The University of Ulm
89069 Ulm,
Germany
