Need Information
Questions:
a) How to make a supercell and distribute all the 5 elements in it with LAMMPS or any other software?
b) How to find minimum energy configuration of this supercell in a specific temperature? (With LAMMPS).
c) Is that possible to find that this supercell is bcc or FCC in a specific temperature? (With LAMMPS).
d) How to find the tensile properties of this supercell with LAMMPS?
Sincerely yours.
J. Sakhaleta
Στις Κυριακή, 30 Ιουνίου 2019, ο χρήστης Majid Vaghari <sakhaleta@…24…> έγραψε:
Questions:
If you have the unit cell structure in a lammps data file you can create a supercell using the replicate command
The simplest and naive way is to carry out an energy minimisation using the minimize and the min_style commands
There are compute commands such as the Auckland and the hexorder that calculate order parameters. Based on these values you can determine if the supercell is bcc or fcc
Have a look at the examples directory where scripts to determine the mechanical properties at zero and finite temperatures are given. Also at https://lammps.sandia.gov/doc/Howto_elastic.html
Hope it helps
Evangelos voyiatzis
Thank you for the information.
Questions:
minimization operates while ignoring the kinetic energy, i.e. will always lead to 0K configurations. there is no such thing as a single minimum energy configuration at finite temperature, but an ensemble of equivalent configurations with the same total energy, which may have a different balance of kinetic and potential energy as well.
