Neighbor list overflow!!
Hii…
I am trying to run a simple simulation with one box filled with small particles with volume 30301 and then I will apply strain and calculate stress. But before that while trying to run the simple box simulation I found the following error,
Neighbor list overflow, boost neigh_modify one (…/neigh_half_bin.cpp:415)
I have read several previous discussions and from there I changed my neigh_modify command as following
neigh_modify delay 0 every 1 check yes page 100000 one 4000
then the error goes away but the simulation hangs after the first step.
I also found this might be because of “bad potential parameter”
I use the following potential…
pair_style soft 1.12
pair_coeff * * 1.0
Can anyone help me figure out what I should do to solve this problem !!!? i am attaching my input file for your kind consideration ! Thanks in Advance. :slight_smile:
Hii...
particles with volume 30*30*1 and then I will apply strain and calculate
Neighbor list overflow, boost neigh_modify one (../neigh_half_bin.cpp:415)
​i don't think it "hangs", it is probably just very, very slow.​
I also found this might be because of "bad potential parameter"
I use the following potential.......
pair_coeff * * 1.0
​no, but look at this:
lattice sq 85.0
​density of 85? seriously?​​
​with a very short cutoff of 1.12 sigma and a 2-dimensional system, you
should *never* reach the point where you have more than 2000 neighbors per
atom (the default setting for neigh_modify one) for any reasonable system.
GI-GO!
axel.​
Thank your Dr. Axel. I didn’t notice the typo. Now the file is running well. :slight_smile:
