Neighbor list problem
Dear All,
I am simulating a system of more than 100 thousand atoms, I need to calculate the coul interaction of all the atom pairs, which means that there is no rcut for the coul interaction. I have tried to increase the value of “ONE” and “Page” under the command of “neigh_modify”, but it does not work. Since I need not calculate the pair list, so I also try to revise the subroutine" pair_coul_cut.cpp", as following
// loop over neighbors of my atoms
num_total is the total atom number of the system
for (i = 0; i < num_total-1; i++) {
qtmp = q[i];
xtmp = x[i][0];
ytmp = x[i][1];
ztmp = x[i][2];
itype = type[i];
for (j = i +1 ; j < num_total; j++) {
factor_coul = special_coul[sbmask(j)];
delx = xtmp - x[j][0];
dely = ytmp - x[j][1];
delz = ztmp - x[j][2];
rsq = delxdelx + delydely + delz*delz;
jtype = type[j];
// if (rsq < cutsq[itype][jtype]) {
r2inv = 1.0/rsq;
rinv = sqrt(r2inv);
forcecoul = qqrd2e * scale[itype][jtype] * qtmp*q[j]rinv;
fpair = factor_coul
forcecoul * r2inv;
f[i][0] += delxfpair;
f[i][1] += dely
fpair;
f[i][2] += delzfpair;
// if (newton_pair || j < nlocal) {
f[j][0] -= delx
fpair;
f[j][1] -= delyfpair;
f[j][2] -= delz
fpair;
But the it still does not work. the error message is
Dear All,
value of "ONE" and "Page" under the command of "neigh_modify", but it does
    qtmp = q[i];
    xtmp = x[i][0];
    ytmp = x[i][1];
    ztmp = x[i][2];
    itype = type[i];
      rsq = delx*delx + dely*dely + delz*delz;
      jtype = type[j];
        r2inv = 1.0/rsq;
        rinv = sqrt(r2inv);
        forcecoul = qqrd2e * scale[itype][jtype] * qtmp*q[j]*rinv;
          fpair = factor_coul*forcecoul * r2inv;
        f[i][0] += delx*fpair;
        f[i][1] += dely*fpair;
        f[i][2] += delz*fpair;
          f[j][0] -= delx*fpair;
          f[j][1] -= dely*fpair;
          f[j][2] -= delz*fpair;
LAMMPS (29 Nov 2011)
Reading data file ...
  orthogonal box = (-300.651 -300.303 0) to (300.651 300.303 19.08)
  4 by 4 by 1 processor grid
  131180 atoms
Setting up run ...
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 11
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
Anyone can tell me how to solve it, thanks!
you have a big problem:
what you want to compute is incompatible with a domain decomposition
based distributed data parallelization, since this is based on having
a cutoff. have a look at the LAMMPS paper.
Why not use a KSpace solver to do this task. Why would
you want to compute the Coulomb interactions
all pairwise for 100K atoms?
