Neighbor settings for fix/reax/c/species
I tried many different neighbor / neigh_modify setting but I always get warning :
WARNING: Resetting reneighboring criteria for fix reax/c/species (../fix_reaxc_species.cpp:101)
Does anyone know how to properly setup neighbor / neigh_modify for that fix?
Bartlomiej
warning :
if you look at the code preceding the line printing the warning, you'll see:
  if (neighbor->delay != 0 || neighbor->dist_check != 0) {
    neighbor->delay = 0;
    neighbor->dist_check = 0;
    rene_flag = 1;
  if (me == 0 && rene_flag) {
    char str[128];
    sprintf(str,"Resetting reneighboring criteria for fix reax/c/species");
    error->warning(FLERR,str);
this warning indicates that the neighbor list settings are adjusted so
that the neighborlists are rebuilt in every step (equivalent to
neigh_modify delay 0 check no). there is no problem with that. the
warning simply informs you that the neighbor list settings are not
what you selected. minimize does the same thing.
That's what I thought so, however when I set neigh_modify to those values I still get this message :confused:
A bug ?
Bartlomiej
A bug ?
have you seen the additional check above the one i quoted, which also
requires neigh_modify every to be commensurate with your Nevery and
Nrepeat settings for the fix?
Yes. I have seen that.
My settings are:
fix 03 all reax/c/species 100 1 100 species.reaxc element H C O Fe
Maybe here I do something wrong ?
Regards,
Bartlomiej
in this case your neighbor->every will be set to 100, that may be too long (look for dangerous builds). If you do not want averaging, I'd recommend something like 5 1 100 or whatever you like for neighbor list rebuilding frequency instead of 5 (1, 10, ...).
Oleg
Bartlomiej Czerwinski <[email protected]...> 4 февраля 2015 г. 15:43:38 написал:
