Dear LAMMPS Help List,
Good morning. I have tried several times on my own to energy minimize a hectorite sample. I have tried the energy minimization command on its own and then NPT at (about) 0 K. However, I realize that fix box/relax is likely the best bet (particularly after reading the manual and help list), but I see no change to my cell when I do that. The energy remains constant the entire time as well. After going through the old posts to the mail lists, I saw someone suggested doing a fix box/relax and an energy minimization after the fix. However, when I try this, I get the same, no change effect to my cell. Do you have any other suggestions? Below, I have included the current order of my input file. I would be grateful for any advice you could give me.
Fraction of in.lammps file
#Dynamics
timestep 0.5
fix 1 all box/relax aniso 0.0 vmax 0.001
#fix 2 all temp/berendsen 0.0001 0.0001 0.0 # Not Necessary when NVT is used
#compute 1 hect msd
#compute 2 hect rdf 1000 9 9 10 9 10 10
#fix 2 all ave/time 10 10 100 c_2 ave running start 10 file tmp.rdf mode vector
#fix 3 all ave/time 10 10 100 c_1 ave running start 10 file tmp.msd mode vector
dump 1 all xyz 1000 dump.water.xyz
dump 2 all custom 1000 dump.all id type x y z
dump 3 all atom 100 dump.atom
thermo 100
thermo_style custom etotal pe ke evdwl ecoul epair ebond eangle edihed eimp elong etail temp press enthalpy
thermo_modify line multi
#thermo_style multi custom cpu
#thermo_style emol elong etail c_1 c_2 c_3 fix_1 fix_2
run_style verlet
run 250000
restart 1000 restart_hect_min.0
write_restart restart_hect_min.0
#Minimization
min_style cg
minimize 1.0e-6 1.0e-8 500 1000
write_restart restart_water-min.300
Thank you very much, and have a great day.
Christin
