No response for NVT/NPT simulations after minimisation
Dear LAMMPS users,
I was trying to run a small system of ionic liquids and TIP4P water (built by PACKMOL) with OPLS-AA force field, but there was no “dynamic response” either in NVT ensemble or in NPT ensemble after energy minimization. However it was indeed still running on HPC and did not crash with any error. The job was later cancelled by myself since there was no “response” and still cost computation resource. I also checked there is also no atom overlap in the system. The latest version LAMMPS brought me the same results. The software works well since I could run it well with other jobs or using ReaxFF force field. Could you please advise me about why NVT/NPT simulation did not run in this case? Was this problem caused by bad initial configuration?
Attached please kindly find my input file and data file. Any suggestions would be greatly appreciated!
LAMMPS (22 Aug 2018)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (…/comm.cpp:87)
Reading data file …
orthogonal box = (-1.0057 -1.00013 -1.00074) to (31.0057 30.9999 30.9993)
5 by 2 by 2 MPI processor grid
reading atoms …
3592 atoms
scanning bonds …
3 = max bonds/atom
scanning angles …
6 = max angles/atom
scanning dihedrals …
10 = max dihedrals/atom
scanning impropers …
2 = max impropers/atom
reading bonds …
2797 bonds
reading angles …
3175 angles
reading dihedrals …
3400 dihedrals
reading impropers …
85 impropers
Finding 1-2 1-3 1-4 neighbors …
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
4 = max # of 1-2 neighbors
7 = max # of 1-3 neighbors
17 = max # of 1-4 neighbors
18 = max # of special neighbors
2334 atoms in group water
1258 atoms in group ils
special bond factors lj: 0 0 0.5
special bond factors coul: 0 0 0.5
PPPM initialization …
extracting TIP4P info from pair style
using 12-bit tables for long-range coulomb (…/kspace.cpp:321)
G vector (1/distance) = 0.225743
grid = 15 15 15
stencil order = 5
estimated absolute RMS force accuracy = 0.0213383
estimated relative force accuracy = 6.42596e-05
using single precision FFTs
3d grid and FFT values/proc = 1960 192
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 14.25
ghost atom cutoff = 14.25
binsize = 7.125, bins = 5 5 5
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut/tip4p/long, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/3d/newton
bin: standard
Setting up sd style minimization …
Unit style : real
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 14.72 | 15.19 | 15.84 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 26639.624 646.82851 27286.452 247260.62
100 0 4540.3368 -107111.96 -102571.62 383210.94
Loop time of 1.23187 on 20 procs for 100 steps with 3592 atoms
97.6% CPU use with 20 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = max iterations
Energy initial, next-to-last, final =
27286.4523604 -101370.450586 -102571.618972
Force two-norm initial, final = 14842.4 26136.1
Force max component initial, final = 3644.63 7794.95
Final line search alpha, max atom move = 5.08344e-06 0.0396252
Iterations, force evaluations = 100 199
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
in.npt (5.21 KB)
data.new17 (395 KB)
Please note, that your system’s pressure is extremely high with ~250Matm
that means that likely your initial geometry is too dense or your box too small or both.
This will lead to extremely high forces, which possibly keep the shake algorithm from converging resulting in a stalled simulation.
The best approach would be to rebuild the system (and check/adjust the box accordingly).
The second best approach would be to allow the box to relax during minimization and minimize for more steps.
Also you need to have some more tight thermostat coupling in your initial MD run, so that the temperature does not increase too much. it is best to first run with a fixed volume before switching to npt or else, you may end up with too low a density and will have to wait for too long a time until the volume/pressure is converged again (since it is much easier for a system to expand than to compress over a larger amount of volume).
with a better relaxed initial structure, it is also possible to run with a much larger timestep (1fs since you are using fix shake)
i am attaching an accordingly modified input, however, when visualizing the trajectory, it looks like your system would be better off to be started with much more solvent or a different arrangement of the solute molecules. as the solute molecules seem to be pushing the box apart and are only slowly rearranging during the npt run (and the box shrinking again).
bottom line. try a generating a better initial geometry, and the simulation will proceed better and equilibration will take less time and effort.
in.npt (5.45 KB)
