Thanks for catching this, @Thomas_Warford. This looks like an unintentional effect of the mixing scheme used to align the (already mixed+corrected) PBE GGA/+U hulls and the r2SCAN hull:
with MPRester() as mpr:
thermo_docs = {
k : mpr.materials.thermo.search(chemsys = ["Pr"],thermo_types=[k])
for k in ("R2SCAN", "GGA_GGA+U_R2SCAN")
by_ehull = {
k : sorted(v, key = lambda doc : doc.energy_above_hull) for k, v in thermo_docs.items()
print(f"r2SCAN only hull ({by_ehull["R2SCAN"][0].material_id}): {by_ehull["R2SCAN"][0].energy_above_hull}")
print(f"Default MP hull ({by_ehull["GGA_GGA+U_R2SCAN"][0].material_id}): {by_ehull["GGA_GGA+U_R2SCAN"][0].energy_above_hull}")
>>> r2SCAN only hull (mp-97): 0.0
>>> Default MP hull (mp-97): 0.008044545
Which tells us that internally (the calculations without any corrections) the thermodynamic hulls make sense, but something is going wrong in the corrections.
We’ll be transitioning to r2SCAN-only data (without any corrections) so this shouldn’t be an issue, but I’ll look into why this is happening in the meantime
