I want to do parallel tempering using lammps. For parallel tempering there
is a command called 'temper'. But, in stead of swaping two temperatures I
want to swap the configurations for two different strengths of the
external potential at the same temperature. I want to know if there is any
command in lammps for that. If not, what changes should I make to the
command 'temper'?
Regards,
Chandana
