Could you please explain how to calculate the force by using fix smd in the attached input file. The system contains 1 atom (1, 1, 1) in 3D periodic box
what force?
with one atom??
what does it interact with???
Dear Axel,
I don’t know I understand right or wrong.
Following a previous question answered by you. I only want to check fix smd with the system with one atom. I have pulled the atom in z direction by using smd and want to calculate force in z direction f_2[3]
this is my input and the result
Dear Axel,
I don't know I understand right or wrong.Following a previous question answered by you. I only want to check fix smd
i saw your input the first time.
it is a pointless input.
other than that. the fix smd documentation tells
you what the number stand for. i don't understand
what else you want to compute here.
