Hi all! I was running a sample simulation with two particles in a box of size 8.
I used the following as pair styles:
- pair_style lj/cut 1.1224
2)pair_style lj/cut 1.1224 and then
pair_modify shift yes
3)pair_style lj/smooth/linear 1.1224
and I dumped the positions of all the atoms in the 3 cases. But in all the cases the coordinates of the atoms are same . Why is this happening?
size 8.
1) pair_style lj/cut 1.1224
because of your input, of course. there is not enough information to
say anything more specific.
#initialisation
units lj
atom_style bond
#potentials
read_data data.xyz
pair_coeff 1 1 1.0 1.0 1.1224
write_data checkbond.data
#velocity
velocity all create 1.0 1
fix 1 all nvt temp 1.0 1.0 0.1
thermo_style custom step temp etotal press pe
dump 1 all atom 100 dump.run.txt
dump_modify 1 scale no sort id
timestep 0.005
thermo 100
run_style verlet
run 1000000
write_data pretunnel.data
this is the input script
which is practically worthless without the data file.
LAMMPS description
2 atoms
1 atom types
-4.000000 4.000000 xlo xhi
-4.0000000 4.000000 ylo yhi
-4.000000 4.000000 zlo zhi
Masses
1 1.0
Atoms
1 1 1 -1.000000 -1.00000 -1.000000
2 2 1 1.000000 1.000000 1.000000
this is the data file
LAMMPS description
2 atoms
1 atom types
Masses
1 1.0
Atoms
ok. i don't even have to run this. of course, you *have* to get the
same thing happening (i.e. nothing), since those two atoms are farther
apart than the cutoff.
But at some point of the simulation they should be within the cutoff distance?
distance?
maybe yes, maybe no. for as long as they are far enough apart they'll
just drift along across their initial directions.
