I have a problem when trying to run LAMMPS together with Kokkos package. I use Makefile.kokkos_cuda from /src/MAKE/OPTIONS/ directory. Compiling and creating of an executable is successful.
When I try to run LAMMPS from the command line using the commands:
mpirun -np 1 lmp_kokkos_cuda -k on t 10 -sf kk -in in.eam
with the test input script:
variable x index 1
variable y index 1
variable z index 1
variable xx equal 80*$x
variable yy equal 80*$y
variable zz equal 80*$z
atom_style atomic
lattice fcc 3.615
region box block 0 {xx} 0 {yy} 0 ${zz}
create_box 1 box
create_atoms 1 box
pair_style eam
pair_coeff 1 1 Cu_u3.eam
velocity all create 1600.0 376847 loop geom
neighbor 1.0 bin
neigh_modify every 1 delay 5 check yes
fix 1 all nve
fix 2 all deform 1 x erate 0.001
timestep 0.005
thermo 50
dump 1 all atom 50 test.dump
run 100
I see the following text in the terminal:
LAMMPS (10 Feb 2015)
KOKKOS mode is enabled (…/lammps.cpp:490)
using 10 OpenMP thread(s) per MPI task
Lattice spacing in x,y,z = 3.615 3.615 3.615
Created orthogonal box = (0 0 0) to (289.2 289.2 289.2)
Created 2048000 atoms
Neighbor list info …
1 neighbor list requests
update every 1 steps, delay 5 steps, check yes
master list distance cutoff = 5.95
Setting up run …
But no additional messages in terminal appear and the program never ends, at the same time I see start of 10 threads in Htop.
Does anybody propose what is wrong and how to solve this problem?
Sincerely,
Vasilii Krasnikov.
