Is it possible to study thermophoresis effect of particle in liquids using LAMMPS
LAMMPS
you've asked this question two weeks ago, and it has been answered by
pointing out that it is not a question of whether LAMMPS can be used
for this (most certainly LAMMPS can model (nanometer scale?) particles
in liquids), but rather whether the effect you want to study can be
modeled on the time and length scales of classical MD simulations in
general.
in the following references they are using MD simulation for thermophoresis effect
https://nanoscalereslett.springeropen.com/articles/10.1186/1556-276X-7-154
effecthttps://nanoscalereslett.springeropen.com/articles/10.1186/1556-276X-7-154
http://link.springer.com/article/10.1007/s10404-010-0612-5
and what now? do *i* have to read them to tell you how to do *your*
research? fat chance. this is *your* research, not mine.
why don't you do what any reasonable person would do now? read those
papers carefully yourself, look at what the people in those papers do
in those MD simulations, check what features LAMMPS has to offer and
compare. if there is a specific required feature missing, consider
implementing it yourself or use the MD code, that was used in the
publications instead. try to reproduce the results in the papers to
teach yourself how to perform and analyze such simulations.
for the future, keep in mind that pretty much any question that starts
with "can LAMMPS do" or "is it possible to do XXX with LAMMS" is not
likely to be well received as it is almost always an indication, that
you have not done your "homework" well enough. consider, for example,
(some of) the suggestions given here instead:
http://www.catb.org/esr/faqs/smart-questions.html
