(no subject)
good day all
I wanna create a pipe geometry with the inner radius and outer radius and many grooves on it do my question is how can I create this pipe?
thank’s everybody
That’s not so straightforward I think. I would create a smooth pipe with create_region cilinder and create_atoms or delete_atoms, then add some grooves manually, and then use the replicate command
That's not so straightforward I think. I would create a smooth pipe with create_region cilinder and create_atoms or delete_atoms, then add some grooves manually, and then use the replicate command
the simplest approach is probably to write a script/program to
generate the desired geometry and then import it via read_data or
read_dump.
