hi,
i m lammps user(beginner). i m using command pair_style reax or reax/c but its not working i have already installed packages of reax. i dont know what exactly the problem is. i have written the error lines below.
waiting for your kind reply.
thank you.
LAMMPS (16 Mar 2018)
Reading data file …
orthogonal box = (0 0 0) to (16.8849 9.7485 15.6207)
reading atoms …
216 atoms
ERROR: Unknown pair style reax (…/force.cpp:246)
Last command: pair_style reax
Please check the keyword and value defined alongwith pair_style command. Or you may be missing something. It would be more easy for us, if you can put complete script here.
Regards
hi,
the error message below, however, shows that the pair style reax is not available in your executable. that means one of two things: 1) either you have “installed” the package (sources), but not compiled a new executable or 2) you have compiled a new executable, but you are not using it, e.g. because you didn’t copy it into a folder that is listed in $PATH.
