Non-numeric box dimensions - simulation unstable
Hi LAMMPS users ,
Recently I changed my LAMMPS version to lammps-10Feb15 , after that I get " Non-numeric box dimensions - simulation unstable " error !
I did not have this kind of errors before with old versions of LAMMPS and with same data and input files that I use !
please let me know what the problem is .
Thanks a lot .
Best ,
saeed.
Hi LAMMPS users ,
It has to be a problem with your input. That it worked with an older version means nothing. It could have been simply because of a bug that got fixed since.
Please let us know what your data and input files are, else we can’t help you. It might be related to this: http://lammps.sandia.gov/threads/msg51360.html
Hi ,
I have attached data file with this Email.I made it by moltemplate !
this is a part of my input :
units real
echo both
newton on
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style opls
pair_style lj/cut/coul/long 12.0 12.0
kspace_style pppm 1.0e-5 #like particle-mesh Ewald(PME)
neighbor 2.0 bin
group C60 type 1
group SPC type 2 3
thermo 1000
thermo_style custom step temp press vol etotal density
thermo_modify norm no flush yes
fix 1 SPC shake 1.0e-4 500 1000 a 3 b 2
velocity all create 1.0 12345689 dist uniform
reset_timestep 0
thermo 200
fix 2 C60 rigid/npt molecule temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0
fix 4 SPC npt temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0
timestep 2.0
dump m1 all image 500 img-*.ppm type type zoom 2
run 100000
Thanks .
Best ,
Saeed .
data.Martini_dihedral (307 KB)
Hi ,
   units real
   echo both
   newton on
   atom_style full
   bond_style harmonic
   dihedral_style opls
   neighbor 2.0 bin
   group C60 type 1
   group SPC type 2 3
   thermo 1000
reset_timestep 0
thermo 200
1000.0
timestep 2.0
here is the problem. you have two fixes that are changing the box.
this is an error.
