water_ethanol_box_3000_0.2.txt (1.5 KB)
water_ethanol_box_3000_0.15.txt (1.5 KB)
water_ethanol_box_3000_0.2.log (11.8 KB)
water_ethanol_box_3000_0.15.log (17.7 KB)
Dear LAMMPS users,
I am attempting to prepare a simulation box containing a mixture of ethanol and water. Ethanol is modeled using the OPLS-UA force field, and water is modeled using the TIP4P model.
As defined in the input script water_ethanol_box_3000_0.2.txt, I generated a system containing 600 ethanol molecules and 2400 water molecules. After energy minimization, I attempted a short npt simulation. However, the run failed with the following error:
ERROR: Non-numeric pressure - simulation unstable (src/fix_nh.cpp)
As defined in the input script water_ethanol_box_3000_0.2.log
, this instability appears to originate from the high energy and NaN pressure reported at the end of the minimization step.
For comparison, I changed the composition to 450 ethanol and 2550 water molecules (keeping the total number constant). The simulation with this new configuration (water_ethanol_box_3000_0.15.txt) ran without errors, but the total energy after minimization remained high, and the temperature spiked immediately after entering the npt phase. If I run the npt simulation for a sufficiently long time, the temperature stabilizes at around 315 K.
Here are additional details:
- Atomic overlaps were checked using
delete_atoms overlap 0.1 all all, and no overlaps were found. - The minimization settings used were the LAMMPS default (
minimize 1.0e-4 1.0e-6 100 1000). - The simulation box size was set to match the target density (0.97 g/cm³).
I would like to ask:
- Is the high energy state after minimization expected behavior in these mixed systems?
- Is it acceptable that temperature spikes and then settles during
npt? - How can I improve the minimization so that the system becomes more stable prior to
npt?
Any advice or suggestions would be greatly appreciated.
asas
