Dear Lammps users,
I am simulating a Couette flow using moving rough walls. I applied periodic boundary condition in x and y directions and a fixed boundary at z-direction in which we have the rough walls. The Rough walls consists of grouped atoms; lower wall is stationary and the upper wall move through “fix velocity” and “fix nve” commands, and also “fix setforce” command set their forces to zero. Other Atoms interact with each other and the walls through Lennard-Jones Potential and integrated through “fix nvt” command. I saved both wrapped positions and unwrapped positions into separate dump files. The input script is provided below.
When I look at the dump file of unwrapped positions, I notice that there are atoms which has escaped the walls and moved beyond the walls and the program did not result in any error. When I take a look at the wrapped positions, you could notice any problem.
I tested several stuff like integrating all atoms motion together and applying thermostat to the flow by velocity rescaling; I also tested “fix move” for the walls (this results in escaping atom error and program stop); I also tested different non-periodic boundary (m and s) instead of fix. None of them helped me to solve the issue. I thought that the walls may be excluded from interactions with the flow atoms, but the motion of flow atoms with the moving wall contradicts this
I hope you guys can help me to solve this issue or a way to avoid it.
Best Regards
