Dear Pylammps developer,
When I run a pylammps code (using version Dec18) on the login node of clusters, the job finishes fine, but when submitting the job via qsub I get an error message:
File “(path_to_lammps.py)/lammps.py”, line 797, in get_thermo_data
for line in lines:
TypeError: ‘NoneType’ object is not iterable
Alternatively, the PBS error can be reproduced on the login node runnincommand like :
python (code name) > redirect_file
In this case the lammps wrapper do not capture the lammps output and this is what is causing the error.
So I modified lammps.py by putting the section (starting with for line in lines) under a try-except structure like:
try:
for line in lines:
