Non-numeric pressure - simulation unstable (src/fix_nh.cpp:1069)
Any idea about this.
Hi Muhahmad,
You will have higher chances of getting a solution to your problem if you start describing what you are trying to do. No one can guess it based only on the error you get.
Germain.
It basically means your simulation input or geometry is garbage.
This is a frequently recurring error message and has been discussed numerous times.
So you can easily getting an idea by searching through past discussions of the mailing/forum.
Hi Germain.
Thank you for guiding. I understand.
