I would like to create a MatPipe without the necessity to define a reducer and cleaner method. Is there a way to do so?
Thanks!
Thanks!
Hey Osmar,
Currently, no. This is a good issue I had not considered: The matpipe is just a way to link together multiple modular data frame transformers. I’ll add it as a issue todo to take of this.
However (in the meantime), each part of the automatminer pipeline can be used with essentially the same syntax as MatPipe (fit/transform/predict operations). You can just use the underlying parts by themselves in whatever order you want (not recommended but if you know what you’re doing go for it). They accept a df as input and return a df as output, just like MatPipe. For example, initialize an AutoFeaturizer and TPOTAdaptor and run the fit/transform actions manually. Just make sure you are using fit/transform/predict correctly and things should be fine.
For example
af = AutoFeaturizer()
tpot = TPOTAdaptor()
training_df = af.fit_transform(training_df, “my_target_col”)
tpot.fit(training_df, “my_target_col”)
prediction_df = af.transform(prediction_df, “my_target_col”)
tpot.predict(prediction_df, “my_target_col”)
Check out the fit/transform methods of MatPipe for more tips on how to use the underlying AutoFeaturizer/MLAdaptor pieces.
Alex
Thanks!
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/e0baeb9c-31f6-4321-9461-bacf4adf90e1%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
