Dear users,
At present I calculate thermal conductivity of an irregular structure. The “fix heat” command can make the simulation go well. But if I use langevin to control the temperature of hot and cold reservoir, the simulation cannot move on and LAMMPS does not give any error. The picture shows where it stops. Could anyone help me figure it out? Thank you.
Yang
Dear users,
there is not enough information here to give any meaningful
recommendation. what you are showing looks like a proper execution of a
simulation. can you provide the corresponding input and point out where the
commands are, that are not executed and how you determined this, and - most
importantly - explain what you have expected to see instead of the
screenshot below.
please also *always* state the LAMMPS version you are using and the
platform, that you are running on.
