Hi all (and the kokkos folks in particular),
Today I ran into the fact that pair_yukawa was GPU-enabled but not KOKKOS-enabled, so I ported it, following the approach I followed for pair_morse.
This time, however, I was smart enough to write down notes about the porting process, which will probably be of use to anyone that is interested in porting pair styles to kokkos.
I have attached the notes here. I also ran into some questions, which I will put here:
- Why does PairKokkos check narg before calling Pair::settings? This seems like a violation of Don’t Repeat Yourself?
- A lot of it is just boiler-plating and renaming. Can we template more?
I know this will make compile times even worse but it will save a lot of copy paste errors. My C++ metaprogramming is not good enough to do this I think. - There is no factor_lj in compute_fpair/compute_evdwl. Are these applied later?
- Which headers are really required? I just included everything pair_morse_kokkos.cpp also included, but it might be worth filtering out some.
I am thinking it would be useful to have this floating around the website as a tutorial, because I can imagine other people might want to take advantage of GPU acceleration for their pair styles. Although KOKKOS looks intimidating, it really is mostly a copy-paste job…
I will file a pull request for pair_yukawa_kokkos.{cpp,h} later.
Hope this helps,
Stefan
P.S.: Are there any plans to have KOKKOS target OpenCL in the future?
porting-pair-styles-to-kokkos.txt (13.5 KB)
