nve and reaxff
I’m doing a simple test of reax/c with nve. I’ve got couple of questions that I want to varify:
  1. Etotal is not ‘true’ total energy for reaxff, because as I understand ‘pe’ by default does not include all the potential energy contributions of reaxff, instead, correct total energy is evdwl+ecoul
  2. Based on 1, fix nve, which tries to keep total energy (etotal) constant during the run at constant temperature, in case of reaxff shouldn’t be keeping evdwl+ecoul constant?
Thanks for your comments,
Manana
I'm doing a simple test of reax/c with nve. I've got couple of questions
1. Etotal is not 'true' total energy for reaxff, because as I understand
'pe' by default does not include all the potential energy contributions of
what makes you think this is the case?
during the run at constant temperature, in case of reaxff shouldn't be
this is nonsense. as has been repeated here many, many times
fix nve does *not* try to "adjust" the total energy. the point of fix
nve is that it *does not do anything* but integrate the equations
of motion. if your system is in equilibrium, then the total energy
*will* be constant. this is the consequence of not adding or removing
energy in any shape or form from the system.
Here I missed kinetic energy, but anyway, according to manual The thermo variable evdwl stores the sum of all the ReaxFF potential energy contributions. Shouldn’t it coincide with ‘pe’? I might be messing up some things here.
  1. Based on 1, fix nve, which tries to keep total energy (etotal) constant
fix nve does not try to “adjust” the total energy. the point of fix
nve is that it does not do anything but integrate the equations
will be constant. this is the consequence of not adding or removing
Yes, that’s true. My point here was that if ‘etotal’ and reaxff total energy are not the same than in NVE, what does E is referring to?
contributions. Shouldn't it coincide with 'pe'? I might be messing up some
things here.
the total potential energy should be the pair energy.
> constant
Yes, that's true. My point here was that if 'etotal' and reaxff total energy
what does it matter? fix nve doesn't care, so it cannot get it wrong.
