NVT volume question...
I can see my epoxy molecules moving around in a trajectory file that I created using
an NVT fix. The volume of the epoxy appears to be smaller than the initial volume
it filled at the beginning of the run. Is there a better way to get the min and max (x,y,z)
values of the epoxy than dumping the coordinates to a file and finding the min and max via
a small program?
Thanks in advance,
Bruce
You can define variables like
variable xlo equal bound(all,xmin)
and print them out with thermo output.
