Obtain the coordinate of fix wall
I am using a moving wall written as follows:
variable ramp equal ramp(0,10)
fix 1 all wall/lj126 xlo v_ramp 1.0 1.0 1.122462
The wall compresses the atoms. I want to output the density as a
function of time and this would mean that I will need the new
coordinate of the wall. I tried using variables but I get an error,
"cannot use ramp in variable formula between runs". How do I get the
coordinates of the fix wall or how do I get the value of ramp?
Jan-Michael
Can't you output the wall position to a file during the run using fix print?
Similarly you could compute volume and density directly using proper
computes and equal style variables.
Cheers,
     Axel
I was hoping that this was the case but the manual says that fix wall
can only output scalar energy and force vector. I also looked at
fix_wall.cpp and fix_wall.h and it has only compute_scalar() and
compute_vector() methods. I am looking at july 2011 version of lammps,
perhaps it is already added in later versions?
How do I this when I don't know the location of the wall? (box size is constant)
But during the run you should have access to v_ramp or not?
Axel
Now this is where I am confused. I should have access with v_ramp in
thermo_style custom, right? Then, how can I use it in a variable? What
is the syntax? fix print ${ramp} does not work and gives me "Cannot
use ramp in variable formula between runs" error.
there must be something wrong with either your input or your lammps binary.
when i modify in.melt as follows, it works just fine for me.
units lj
atom_style atomic
boundary p p m
lattice fcc 0.8442
region cube block 0 10 0 10 0 10
region box block -2 10 0 10 0 20
create_box 1 box
create_atoms 1 region cube
mass 1 1.0
velocity all create 3.0 87287
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
neigh_modify every 20 delay 0 check no
fix 1 all nve
variable ramp equal ramp(12,10)
variable step equal step
fix 2 all wall/reflect zlo EDGE
fix 3 all wall/lj126 zhi v_ramp 1.0 1.0 1.122462
fix 4 all print 10 "wall position \{step\} {ramp}"
thermo 10
thermo_style custom step elapsed ke pe press temp vol v_ramp
dump id all atom 50 dump.melt
run 250
Thanks Axel,
I needed the quotation marks for fix print to work. Now, how do I put
the value of ramp on an "equal" style variable? I still get the
"Cannot use ramp in variable formula between runs" error when i use
this line:
variable dens equal count(polymer)/8/xhi/yhi/${ramp}
Jan-Michael
Thanks Axel,
this line:
as you should, you need to use v_ramp
and ${var} style variable is expanded immediately,
but you don't want then, and thus need to
use the v_var style representation.
I still get the
The reason you cannot use ramp in a variable that gets
evaluated between runs, is that ramp is defined as a quantity
that only makes sense during a run (i.e. the fractional value
between the start and end of the run). So you have to insure
you do not directly or indirectly evaluated a formula
that has a ramp() in it.
