odd error on tersoff style with lammps-12Dec18
This is strange. I run a simple test calculations using two versions of lammps
and get an error on the later version.
Here’s the input:
atom_style atomic
atom_modify map hash sort 0 0.2 # should hash be used for scatter_atoms???
read_data data.set # look to this file for the data
mass 1 72.64
pair_style tersoff
pair_coeff * * SiCGe.tersoff Ge
neighbor 0.3 bin
variable pe equal pe
thermo 1
thermo_modify norm no
run 0 post no
So there are also two files present: data.set and SiCGe.tersoff
lammps-1Feb14 runs it fine.
lammps-12Dec18 drops this error:
ERROR: Unknown pair style tersoff (…/force.cpp:262)
Last command: pair_style tersoff
Exactly the same input files.
What gives???
…Murray Daw
What is the output of running the LAMMPS executables with the -help flag?
Could it be that the 12Dec18 executable is missing the MANYBODY package?
Axel
