one problem about fix smd commands
When I use the command fix smd, they gave me this error below:
" ERROR: Invalid fix style (modify.cpp:668)"
Could you tell you the reason? actually, I have installed all user packages.
Thanks in advance,
best wishes,
yancheng
Apparently you didn’t.
Axel
Thanks Axel, I will try again.
Besides how I can define the value of “K = spring constant” in the command fix smd more reasonably?
yancheng
What is wrong with the current way? What is unreasonable about it?
Axel
