Now I am struggling in using command “orient” to build a periodic supercell system.
From the manual and mail list, I learned one should make sure the size of the simulation box coincident with the periodic size along the certain “oriented” direction, thus, the periodic system would be built.
And the periodic size should be integer multiple of lattice spacing. Is my understanding right?
If so, there seem to be some problems when I build a periodic supercell followed by this script.
script
------------------------ INITIALIZATION ----------------------------
atom_style atomic
variable latparam equal 4.05
----------------------- ATOM DEFINITION ----------------------------
lattice fcc ${latparam}
lattice fcc ${latparam} orient x 1 1 2 orient y -1 -1 1 orient z 1 -1 0
region whole block 0 66.1362 0 70.1481 0 17.18268 units box
create_box 1 whole
create_atoms 1 region whole
Script end
As depicted by lammps.log file, the Lattice spacing in x,y,z = 6.61362 7.01481 5.72756 after the command lattice fcc ${latparam} orient x 1 1 2 orient y -1 -1 1 orient z 1 -1 0
Was inputted.
So I make sure the Size of the whole box keep to 66.1362, 70.1481,17.18268, respectively, which are also 10 times, 10 times and 3 times of the Lattice spacing in x,y,z.
But still, I can not get the periodic system. (Especially in x and y direction.)
Is there any way or method or any algorithm to get a periodic system?
Thank you in advance!
Sincerely
Li Li
