Out of range atoms - cannot compute PPPM
Hello All,
I am running a simulation of water molecules + ions.
And I faced the error -
ERROR on proc 0: Out of range atoms - cannot compute PPPM.
My lammps input script is as follows-
Lammps input for H2O + KCl
units real
atom_style full
atom_modify id yes
processors * * *
read_data system.data
Group definition
group hydrogens type 2
group oxygen type 1
group fluidmols type 1 2
group potassium type 3
group chloride type 4
group ions type 3 4
group solutions type 1 2 3 4
Interaction potential for atoms
pair_style lj/cut/coul/long 10.0 10.0
kspace_style pppm 1.0e-4
pair_coeff 1 1 0.15535 3.166 # O
pair_coeff 2 2 0.0 0.0 # H
pair_coeff 3 3 0.43 2.84 # K
pair_coeff 4 4 0.0128 4.83 # Cl
pair_modify mix arithmetic
bond_style harmonic
bond_coeff 1 1000.00 1.000
angle_style harmonic
angle_coeff 1 100.0 109.47
print “Angle”
dielectric 1.0
neigh_modify delay 10 every 1 check yes
reset_timestep 0
min_style cg
thermo 50
thermo_style one
dump 1 ions dcd 100 ions.dcd
dump 2 fluidmols dcd 100 fluidmols.dcd
dump 3 all custom 1000 wation.lammpstrj id type x y z
restart 1000 lammps.restart1 lammps.restart2
Hello All,
LAMMPS Molecular Dynamics Simulator
*# Lammps input for H2O + KCl
units real
atom_style full
atom_modify id yes
processors * * *
Group definition
group oxygen type 1
group ions type 3 4
bond_style harmonic
print “Angle”
dielectric 1.0
reset_timestep 0
min_style cg
thermo 50
thermo_style one
Hello Axel,
Yes I went through the link you have sent. And I changed my neigh_modify command and timestep also according to solution in documentation. But I am getting segmentation fault.
you are needlessly spamming this mailing list with redundant data again.
please stop this.
Sorry, but that time a single had missed when I was copying my script in the mail.
*single line - run
Hello Axel,
​there are many more reasons for the error you quote and corresponding
different approaches to cure them.
​simplify your input, observe what is ​going on by visualizing the
trajectory, observing energies and more.
also, there are a gazillion of discussions of what to do in the mailing
list archives.
most likely your starting geometry is bad or your force field parameters
are bogus.
the mail.
​regardless ​of that, you copied *twice* an input that *cannot* produce the
error you quoted, because it will exit _before_ with a *different* error.
so you have now wasted my time due to your carelessness and stopped any
desire on my side to help you.
