output when running in parallel
I upgraded my LAMMPS to the current version, after this update every line of output is printed by each processor, for example, if I run on 20 CPUs, it prints every output line 20 times. Has anyone noticed the same or does anyone have any idea how to get rid of it?
Manana Koberidze
Problem disappeared, seems something related to our local mpi.
yes. this would happen, if you use an mpirun or mpiexec command
from a different MPI library than the one that a program is compiled with.
