I'm not very at ease with the script syntax, to say the least
I'd like to do something that sounds trivial but I don't manage to.
During an NPT run I'm doing a running average of box size with:
fix 5 all ave/time 100 1 100 lx start ${avg_starttime} ave running
Now I want to output the last value of this fix. So I tried:
variable foo equal f_5
fix 6 all print \{timelength\} {foo}
but get the following error: "Invalid fix ID in variable formula". Double quoting "${foo}" just delays the error to step 200. Removing the start keyword in fix 5 does not solve the issue.
My Lammps version is 30 Sep 2013.
Here is the complete script:
variable timelength equal 200
variable thermo_step equal 100
variable avg_starttime equal ${timelength}/2
atom_style atomic
read_data data.CuZr256_NPT
velocity all create 1500 42
group Cu type 1
group Zr type 2
pair_style sw
pair_coeff * * CuZr.sw Cu Zr
neighbor 2.0 bin
neigh_modify every 1
fix 1 all npt temp 1500 1500 0.1 iso 1.0 1.0 1 drag 0.5
timestep 0.0010
thermo_style custom step temp pe etotal press vol lx
thermo ${thermo_step}
#fix 6 all print \{timelength\} "{foo}"
dump 3 all custom ${timelength} config_*.snap id type x y z vx vy vz
run ${timelength}
Thanks for your help.
