Hello everybody
I’m a new user to ovito, I’m viewing the results of Lammps dump file where I have three types of atoms
My question is in ovito how can I view only one type of atoms?
Regards
Isra
Hello everybody
Regards
Isra
Hi Isra,
you could use a Select Type Modifier in conjunction with a Delete Selected Modifier to select and delete atoms of a specific type from the active scene. You’ll find these modifiers when you click on the drop-down menu “Add modification” in the pipeline modification panel in the GUI.
I have linked the corresponding manual entries for you.
-Constanze
Thank you very much for your reply
One more question if possible, is there is a way to make some of the atoms semi transparent to allow for the deformation process of the inner atoms to be clear and visible?
Thanks and regards
Isra
Yes, please have look at the following “How-to guide” in our User manual: https://www.ovito.org/docs/current/howto.transparent_particles.php
-Constanze
