Hi, everyone
When I run the simulation with a script input file.
In the input script , run 200 timestep first.After it is finished,
then setting up run 20000 encountered an error:
The error :
Total # of neighbors = 727623362
Ave neighs/atom = 1833.73
Ave special neighs/atom = 0.116129
Neighbor list builds = 7
Dangerous builds = 0
1 rigid bodies with 25600 atoms
Setting up run …
Memory usage per processor = 669.431 Mbytes
Step Temp PotEng KinEng TotEng E_pair E_mol E_bond E_long Press Volume
200 0.34463851 42.827995 0.48360696 43.311601 42.816002 0.011992606 0.011992606 0 117.43735 132800
210 0.38161853 41.593909 0.53549841 42.129407 41.582004 0.011905344 0.011905344 0 113.31772 132800
220 0.52556167 41.102628 0.73748368 41.840112 41.090558 0.012070093 0.012070093 0 111.18768 132800
230 0.78885702 41.172059 1.1069475 42.279006 41.160551 0.011507438 0.011507438 0 112.1653 132800
240 1.2330369 41.285406 1.7302339 43.01564 41.273953 0.011453221 0.011453221 0 113.81138 132800
p0_19405: p4_error: Found a dead connection while looking for messages: 3
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
p0_19405: (985.765625) net_send: could not write to fd=4, errno = 32
I performed the parallel simulation with 6 processors.
I will appreciate your help
Edw
Hi, everyone
The error :
Setting up run ...
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
Killed by signal 2.
help with what?
there is - by far - not enough information to even tell
whether you have a hardware problem or just a bad
input or set up a simulation with a bad model.
