Dear developers,
I think that the way you are writing the lj/class2 potential is not correct. The sigma value (where V(R)=0) should be substituted with Ro where V'(Ro)=0. Do you define sigma in another way? If I use this potential but instead of sigma use Ro is the implementation influenced someway?
Many thanks.
Kind regards,
Christos
Dear developers,
hmm... how is it possible then, that people have used
it correctly for such a long time?
sigma is the minimum of the potential. the potential is 0 only for infinite R.
this can be easily validated using a function plotting tool like
gnuplot or grace.
just run some tests.
i should perhaps point out in addition, that the definition
of sigma in the class2 LJ potential differs from the regular LJ.
for which the minimum is at: 2^1/6 * sigma
this is reflected in the functional form that is provided.
cheers,
Hi christos
it is correct that the definition of sigma is the radius in which force=grad(v) is zero but
note that in regular Lj formula if you set r=sigma, then v=0
this is because we can shift the plot of v® up and down in y direction without affecting
the results because the important quantity is force=v’, not v itself
(derivative of a constant is zero)
so it is prevalent to shift the V® up until in r=sima we have both v®=v’®=0
best,
Dear Axel,
Thanks for the reply. So if I understand well the sigma in the class2 potential is actually the distance at the minimum (where the V'(x)=0). In the case of the 12-6 instead sigma is where V(x)=0. I wanted to be sure that in the case of the 9-6 the sigma was not converting to Ro in the code.
Kind regards,
Christos
Dear Axel,
if you want to make absolutely certain about your parameters,
use the pair_write command to plot out the potential and forces
for a given set of parameters.
http://lammps.sandia.gov/doc/pair_write.html
