I am using a system with metal nanoparticle bonded to my polymer molecule. I have some question related to atomstyle and pair coefficient
What should I use in my atomstyle , is this molecular or hybrid atomic full .( metal atoms are uncharged and the polymer chain is like biomolecules , molecular +charge).
I have used pair interaction , 1 1 (for metal atoms using EAM), 1 4 (metal connected to polymer ) , 2 2 , 3 3 , 4 4.
This job run tells me this is not sufficient ( I have the error message below) . I also used hybrid pair style asm pair_style hybrid lj/cut 5.0 eam . This job run gives me proper output with use of only LJ potential only when I use hybrid the error show up. Which pair interaction I am missing here.
Finding 1-2 1-3 1-4 neighbors …
12 = max # of 1-2 neighbors
132 = max # of 1-3 neighbors
1572 = max # of 1-4 neighbors
134 = max # of special neighbors
ERROR on proc 0: All pair coeffs are not set
ERROR on proc 1: All pair coeffs are not set
ERROR on proc 3: All pair coeffs are not set
ERROR on proc 2: All pair coeffs are not set
ERROR on proc 5: All pair coeffs are not set
ERROR on proc 7: All pair coeffs are not set
ERROR on proc 6: All pair coeffs are not set
ERROR on proc 4: All pair coeffs are not set
Thanks for your time
Kirtana
