pair coeffs with hybrid/overlay pair style
Dear LAMMPS Users,
I am running simulations with a pairwise force field composed of a combination of (up to) 5 gaussian function and a r12 repulsion. For this I use the pair_style hybrid/overlay:
pair_style hybrid/overlay lj/cut/coul/cut 15.0 gauss/cut 15.0 gauss/cut 15.0 gauss/cut 15.0 gauss/cut 15.0 gauss/cut 15.0
Followed by the pair coefficients:
1 1 lj/cut/coul/cut 7.253484e+05 1
1 1 gauss/cut 1 -4.858088e-01 4.594137 5.655362e-01
1 1 gauss/cut 2 3.860048e-01 6.773912 6.827464e-01
1 1 gauss/cut 3 1.928422e-01 10.612959 9.192791e-01
1 2 lj/cut/coul/cut 1.813008e+06 1
1 2 gauss/cut 1 2.577609e-01 7.202817 5.013672e-01
1 2 gauss/cut 2 -1.029851e+00 5.160473 7.161932e-01
1 2 gauss/cut 3 1.899216e-01 10.383490 7.565813e-01
1 2 gauss/cut 4 -4.852090e-01 4.220978 4.020288e-01
1 2 gauss/cut 5 5.214207e-02 12.734010 3.953330e-01
etc...
Because this is long and messy (I can have up to 32 types in one single simulation), I wanted to move this section to the data file in a "PairIJ Coeffs" section:
PairIJ Coeffs
etc...
When I run LAMMPS, I get the following error:
ERROR: Unknown identifier in data file: 2 6 lj/cut/coul/cut 2.091260e+06 1 (../read_data.cpp:464)
Which corresponds to pair coefficient line #106. Since I have 14 types in this simulation, I have indeed 105 possible combinations. Does it mean that read_data cannot properly interpret the hybrid/overlay pair_style and that I have to keep all those pair coefficient in the body of the run input file or is there something I am missing?
Thank you in advance for your help!
BW
Aymeric
Dear LAMMPS Users,
etc...
if it is just about keeping this away from the main input file, you
can just write the coefficients to a second file and use the "include
name_of_second_file" syntax.
PairIJ Coeffs
etc...
there is indeed currently is no way for read_data to read an arbitrary
amount of lines followed by the coeff keyword, as required by pair
style hybrid/overlay. the whole parsing of input is based on knowing
how many lines have to follow a specific section header keyword, which
is not possible here.
