I know this question has been asked in some form before, but I am curious as to what might be going on here.
I have 2 data files of silica. One has 1296 atoms, the other 9 atoms (unit cell).
I am using a tabulated potential as part of a hybrid potential form.
The 1296 atom data file works great - no issues.
When I Take the first 9 atoms from the 1296 atom data file and attempt to run a simulation, I get this error:
“Pair distance < table inner cutoff”
I get this error even with replicating to over 1million atoms.
Now I realize the answer may just be to make the inner cutoff smaller (It is currently 1 Angstrom). But these atoms are separated by more than 1 Angstrom - As I said, they have the exact coordinates from the data file with 1296 atoms that works fine.
Any ideas why loading in a small system and replicating produces this error, but having a larger data file to begin with does not? Has this been resolved before?
Ben
cell).
"Pair distance < table inner cutoff"
before?
nobody can say anything without actually seeing those inputs.
my guess is that you have close contacts through periodic boundaries,
i.e. a bad input.
The key is the treatment of your periodic boundaries when the system is reduced to 9 atoms. As Axel said, you likely had a bad input due to bad boundary conditions.
Ray
I.e. if you changed your box size when you shrunk the # of atoms,
then you have a totally different problem, not a subset of the
original.
