Pair_style error
I’m reading a .data file in which the pair_style isn’t defined. So I manually wrote “Pair_style lj/cut/coul/long” before pair-coefficients inside the .data file. It gives me this error:
“ERROR: Unknown identifier in data file: pair_style lj/cut/coul/long (src/read_data.cpp:727)
Last command: read_data layer.data”
The pair_style command should be used in the lammps input file (the one you specified by standard input or -i switch; see 4.1. Basics of running LAMMPS — LAMMPS documentation) instead of data file. Also see 4.1. Basics of running LAMMPS — LAMMPS documentation for list of attributes that can be specified in the data file.
This is the version where pair_style is used inside the lammps input file:
Initialize simulation
units real
atom_style full
Information of pair of atoms
Read data file
Define simulation parameters
timestep 0.001
thermo 1000
thermo_style custom step temp press pe ke etotal
dump 1000 all custom my_dump_file.dump id type x y z
run 0
Define NVT ensemble
fix 1 all nvt temp 300.0 300.0 100.0
Run simulation
run 10000
and the error it gives is:
ERROR: Illegal pair_style command (src/KSPACE/pair_lj_cut_coul_long.cpp:595)
Last command: pair_style lj/cut/coul/long
Please check the documentation pair_style lj/cut/coul/cut command — LAMMPS documentation. Namely you need to specify additional arguments (cutoff) after pair_style lj/cut/coul/long.
Also check out kspace_style kspace_style command — LAMMPS documentation which is required when using long-range coulomb pair styles.
It worked. Thanks a lot
