Dear Lammps’ Users,
I am trying to simulate a molecular system using Reax FF (reax/c). In the meantime, I would like to add some additional “particles” which interact with each other by LJ. I searched the online documents and found the pair_style hybrid. Can anyone give any suggestion on the input command?
FYI, I have seven-atom types which are C H N O S Al Si. C H N O S use reax/c. Al and Si follow LJ. Should I use some input command as follow? Also, do I need to change control file?
pair_style hybrid lj/cut 12.0 reax/c control.reax_c.rdx
pair_coeff * * reax/c ffield.reax C H N O S NULL NULL
pair_coeff 1 6 lj/cut 1.0 1.0
pair_coeff 2 6 lj/cut 1.0 1.0
pair_coeff 3 6 lj/cut 1.0 1.0
pair_coeff 4 6 lj/cut 1.0 1.0
pair_coeff 5 6 lj/cut 1.0 1.0
pair_coeff 6 6 lj/cut 1.0 1.0
pair_coeff 7 6 lj/cut 1.0 1.0
pair_coeff 1 7 lj/cut 1.0 1.0
pair_coeff 2 7 lj/cut 1.0 1.0
pair_coeff 3 7 lj/cut 1.0 1.0
pair_coeff 4 7 lj/cut 1.0 1.0
pair_coeff 5 7 lj/cut 1.0 1.0
pair_coeff 7 7 lj/cut 1.0 1.0
I would really appreciate your help on the input script. Thanks in advance.
Regards,
Shuai
