sir,
I am working on graphene of 3 layers. …i got some problem with paristyle and pair coefficient …and get following error….ERROR: All pair coeffs are not set (pair.cpp:159)
code:
boundary s s s
atom_style full
neighbor 1.0 bin
neigh_modify every 3 delay 3
lattice fcc 2
#Reads configuration from file
read_data x80y1.txt
region 66 block INF INF INF INF INF 1.5 units box
group lower region 66
region 77 block INF INF INF INF 1.5 4.5 units box
group mid region 77
region 27 block INF INF INF INF 4.5 7 units box
group upper region 27
set group lower type 1
set group mid type 2
set group upper type 3
mass 1 12.010700
mass 2 12.010700
mass 3 12.010700
pair_style hybrid lj/cut 10 tersoff tersoff tersoff
pair_coeff * * tersoff 1 /home/cntl/lammps/potentials/C.tersoff C NULL NULL
pair_coeff * * tersoff 2 /home/cntl/lammps/potentials/C.tersoff NULL C NULL
#pair_coeff * * tersoff 3 /home/cntl/lammps/potentials/C.tersoff NULL NULL C
pair_coeff 1 2 lj/cut 0.055119926 1.412
pair_coeff 2 3 lj/cut 0.055119926 1.412
pair_coeff 1 3 none
for double layer my code working fine
and the code was
region 77 block INF INF INF INF 1.5 INF units box
group upper region 77
set group upper type 2
mass 1 12.010700
mass 2 12.010700
pair_coeff 1 2 lj/cut 0.055119926 3.412
any help is greatly appreciated
regards
Ragesh
india
sir,
I am working on graphene of 3 layers. ..i got some problem with paristyle
and pair coefficient .........and get following error.....ERROR: All pair
coeffs are not set (pair.cpp:159)pair_style hybrid lj/cut 10 tersoff tersoff tersoff
NULLpair_coeff * * tersoff 2 /home/cntl/lammps/potentials/C.tersoff NULL C
NULL
NULL C
What happens if you uncomment this line?
pair_coeff 2 3 lj/cut 0.055119926 1.412pair_coeff 1 3 none
LAMMPS does not know how to calculate forces between atoms of type 3
and type 3 (or type 2 and type 3). You either need to add something
like:
pair_coeff 3 3 none
OR you could uncomment the line above beginning "#pair_coeff * * tersoff 3"
Also, try replacing:
with
Cheers
Andrew
